get buzzed
I'VE GOT A QUESTION THAT EVERYONE IVE TALKED TO CANT ANSWER, AND IT TO ME THIS WOULD BE A VERY COMMON SCENARIO, I GOT A MACHINE THAT IS 30 AMP THREE PHASE NO NEUTRAL WITH 230 VOLT MOTORS ON IT,, THE SUPPLY VOLTS ARE 3 PHASE 208 VOLT, THE COMPUTER IS SHUTING IT OFF BECAUSE OF LOW VOLTAGE, ... SO IVE ORDERED BUCK BOOST TRANSFORMER AT 1 KVA.. BUT DO I NEED THREE OR TWO TRANSFORMERS?..THE GUY AT THE SUPPLY HOUSE DOESNT KNOW I ASKED IF ITS THREE PHASE OR SINGLE .. HE SAYS ITS BOTH... I THINK HE'S WRONG . BUCK BOOST ARE USAULLY SINGLE PHASE RIGHT ?... WILL I NEED 2 OR 3 AND IF TWO DOES IT MATTER WHICH TWO PHASE'S YOU USE( OPEN DELTA)......... IM GONNA BE DOWN ANOTHER DAY IF I ONLY HAVE ONE TRANSFORMER.......THANKS MUCH APPRECIATED
