Buck Boost transformer KVA
Bea
Checkto see if this is correct
1-Name plate VA of buck boost is the voltage boost or bucked x the output load amps
2-VA of output load could be quite larger say output voltage 230 x load amps 8 amps = 1840 va but buck boost would be voltage busted 22 x load amps 8 =176 va is this correct
