I am trying to understand the buck boost transformers and have been searching everywhere for literature that talks about the neutral. I have been unsuccessful so i'm hoping someone might be able to help me out.
My situation is a 120/240V single phase service feeding a 208V single phase panel (panel feeds both 120V and 208V loads). The contractor suggested using a buck transformer to step down from 240V to 208V. My concern is the neutral conductor and a 120/208V single phase voltage at the panel.
From what i can gather the buck boost transformer would buck the voltage on the phase conductors only (with no connections for the neutral). I know not to derive a ground/neutral on the transformer secondary (for this single phase application), but does this mean the neutral just bypasses the buck transformer and feeds through? I'm not sure if i need to be cautious of potentially elevated neutral voltages or currents? It doesn't appear there are any codes that prohibit this but i'm not convinced this is acceptable or safe or if it's an inappropriate application of the buck boost transformer.
Does anyone know if this is a standard practice or if there are any other issues that could arise from this? Thanks in advance!!
