Hey guys, I have looked all over the forum and beyond for help on buck boost wiring. I believe I have an understanding of Single Phase Buck Boost Transformers but when I try to apply the math to a 3 Phase System. I am not coming out with numbers that make sense. I hope that the forum community can shed some light.
I do have a specific question in mind but I'd like to ask a general question to help me, and hopefully others, grasp the method of bucking or boosting a 3 phase system to a different 3 phase voltage using 2 Single Phase Buck Boost Transformers. This may be the key for my other question and probably the rest to come.
The photo attached is one of the wirings in question.
According to this diagram, I will get 208V between A+B and B+C but not A+C. Does that sound correct?
For example, I have 218V Input and I want a 208V Output. This wiring configuration only drops voltage on A and C Leg.
I cannot run a 208V 3 Phase Equipment with significantly lower voltage between the A+C Leg . Yet, this is the diagram I was referenced to from the Buck Boost Transformer.
I believe my math or my understanding..or both... is incorrect somewhere.
I've attached a photo of the nameplate of the transformer to assist with any info.
I'd appreciate any help.
