hillbilly1
- North Georgia mountains
- Owner/electrical contractor
I have a customer that has a piece of equipment that specs 240 volts max, with 230 volts preferred. Problem is the utility is high because they have too much load on the transformer, and long runs to the other end of complex. This is the second unit in, so the voltage is at 245. The phase converter is pumping out 260-280 on the generated leg unloaded. I’m bucking it 12 volts, and the transformer manufacturer is saying to use an open delta with two transformers. I would be more comfortable using a wye, but don’t know how the phase converter would react because a neutral would be connected. The manufacturers instructions does not give a delta connection, which I would be more comfortable with. Anybody had this problem before?
