I agree with __dan. Talk to you insurance agent. You should already have liability insurance, why do you want to insure the clients property against theft, or anything else you are not liable for?
Keep all your tools, unused materials, etc. in your own locked trailers, or other containers, then they are covered by your insurance if stolen. Everything you have installed belongs to the client and is their responsibility to insure it.
i've seen language that that you own it until COI issued... fine print is m'portant....
i use a mul-T-lock for my bin, both a large one on the bail handle, and a hockey puck lock
as mobile mini has a puck lock box fitted on the door... so you can burn or grind it off is about
it.
job i'm currently doing, inspector will give me rough walls with just a string in the conduit...
i'm not pulling anything until the building is secure... crackheads in LA will crawl in a live
distribution vault to steal $20 worth of ground wire.
i just had delivered my service for this building.... 200 amp 3 phase 208, surface mounted.
that isn't getting mounted on the building until almost done. it won't last the weekend.
my cost was $1,825 for the spec'd unit.... turns out there was ONE of them in north america.
it's in my bin. if it gets stolen they will have to make another one.... they usually only have two available...
made by milbank... i've not seen a panel for plug in breakers with copper busbars in a very long time,
and a pull out fuseholder for the main, with bolted in fuses.
made in the USA, by people who drive SUV's.... no wonder it's almost $2k.
