Building steel as grounding electrode
cppoly
New York
In an article from Mike Holt, he says "The 2011 NEC no longer allows the structural metal to serve as a grounding electrode when supplemented by a ground rod."
This doesn't make sense, does it? I thought when multiple electrodes were present they all have to be bonded together, so why would building steel not be allowed to be used an electrode if connected to a ground rod?
Not to speak for MH, but maybe I can clarify.
The structural metal frame is not an electrode, only the part that is in the ground for 10'.
One may attach a GEC to the frame as long as part of that frame eventually qualifies as an electrode or is attached to a CEE.
You can not attach a GEC to a frame that is only supplemented by a ground rod. Basically in order to use the frame to extend the GEC to a ground rod or such, part of that frame has to qualify as an electrode or be properly attached to a concrete encased electrode, not just a rod or such.
