Is it code compliant to take the building Steel GEC to a steel Purlin rather than a Column. Also can you jumper the water pipe GEC from water pipe to building steel rather than back to the service.
You may get various opinions. Most inspectors I know have required the bond to the column or framing member due to the heading of 250.52(A)(2) "Metal Frame"
Once the steel meets the requirements to be a grounding electrode {250.52(A)(2)} you can connect a jumper from it to the water as you will be connecting electrodes.
