Regarding residential wiring, I've worked with a couple of different EC's that had different perspective's on what was/is allowed regarding "grouping" of NM cables. Especially as you start pulling HR's through I-joists in the bsmt towards the panel.
Specifically, one EC had an SOP to drill a series of 1 1/2" holes spaced about 6 inches apart through the joists and pull a bunch of hr's through the holes (as well as interconnecting various circuits with the holes when it was convenient) heading towards the panel. These joists were usually on 16" center's. Usually we pulled hr's through the holes until there was a risk of damaging the cables (~6-7 cables). He didn't consider this bundling because they weren't in a raceway.
Another EC I worked with had a general practice of no more than 3-4 cables through a drilled hole, trying to maintain/follow the "no more than 3 ccc's"- especially through drilled holes that were later filled with expansion foam (which I can understand). This practice resulted in a LOT more drilled holes in a house.
Please give me your opinions/perspectives on these practices.
Thanks!
Thanks!
