Kartracer087
- Chicago
- Consulting Engineer
Hi,
I am wondering, how do they Y connect the primaries of single phase pad mounted transformers for homes and small businesses. What I am curious to know is if they use the concentric neutral contained in the medium voltage cable or do they use a separate neutral brought down from the utility riser? If they use the concentric neutral, is it connected to the utility pole's multigrounded neutral through a cable splice at the riser pole? I am mainly thinking about radial systems namely systems where one riser feeds one transformer. I know they have loop systems in the single phase pad mount transformers where they can series connect each primary of the transformer until it reaches the end of the line where it would either connect to another phase on the pole or the neutral would connect to the final terminal much like connecting receptacles/light fixtures in a house.
Thanks
Thanks
