fisherelectric
- Northern Va
We are replacing existing switches and receptacles in a residence with new Adorne devices made by Legrand (http://www.legrand.us/adorne.aspx#.VEvMPOduAXk). We are using their "Tru-Universal" dimmer which is capable of dimming LED, CFL, Mag Low Volt, Electronic Low Voltage in forward and reverse phase, Incan, and halogen loads. The recessed fixtures we are dimming are magnetic low voltage with dimmable LED MR16 lamps. We had a situation where after installing a dimmer, within a few minutes the breaker tripped and we discovered that the 5 fixtures controlled all had fried transformers.
My electrician did not inadvertently hook 240volts up to these lights.
My question is, is it possible that this dimmer somehow caused these 5 transformers to burn up?
The dimmer no longer dimmed. We installed many of these dimmers and this is the only problem we've had.
Thanks in advance for any thoughts on this
