Mountain Sparky
- Colorado USA
Why would losing a neutral on a 277 volt lighting circuit burn up a magnetic metal halide ballast?
Is the circuit a part of a multi-wire branch circuit ??
See if this helps. Just use 480/277V instead
My understanding, and I might be wrong, is that over voltage drives the ballast core onto saturation. When saturated there is not enough counter EMF to limit current on the windings and thus the windings will begin to have more current flow. The current flow heats the coils until they overheat.
Am I correct? I am curious about this as well.
