Help me for the bus bar calculation:
Given a 1.5 MVA, 3 phase, 400 V. What would be the size of my busbar (copper material)?
Just comment if you need more details other than these.
Thank you.
The cross sectional area required for a specific current rating is something typically defined in the electrical code or design standards that you need to adhere to in the location where it is being installed. Even then, it's not an easy thing that you just punch into a calculator, there are a lot of factors that go into it. Off the top of my head, X-sectional area, shape, number of parallel bars (you will need 3750A total, won't be one bar), spacing, ambient temperature, allowable temperature rise, air flow, fault bracing, etc. etc. It's an art form as much as it is an engineering question.
No offense intended but bottom line, if you have to ask an anonymous web forum, you might not be the right person for the job.
