Bus bar joint contact area vs cross-section area
GoldDigger
Placerville, CA, USA
Retired PV System Designer
I'm trying to understand how you can justify the joint of bus bars that are 2 different sizes. I saw in a Legrand busbar and distribution book (http://www.legrand.com/files/fck/File/pdf/Power_guide/EX29016.pdf) on page 26 that the contact area must be at least 5 times the cross-section area. I was just curious if anyone else has heard of that rule of thumb and if it's defined anywhere else?
I think that the simple answer is that the contact area has to be at least 5 times the cross-section area of the smaller bus bar, since that area determines the spec limit for normal current through the joint.
