Bus bars traversing over bus bars
mbrooke
Batteries Included
United States
Technician
When crews service a bus bar, how far must de-enerigzed bars from energized bars? Can bus bar insulators be replaced live and how often do they fail prior to 40 in-service years?
The design to the right is economical to build, but repair down the road is being called into question.
Julius Right
Electrical Engineer Power Station Physical Design Retired
In my opinion, what do you need are bus disconnectors. So you could de-energize a system and work on another.
If it is height enough you may pass the connection bar under the main busbar. Double Busbar Connections.jpg
mbrooke
Batteries Included
United States
Technician
If it is height enough you may pass the connection bar under the main busbar. View attachment 16768
What are those? :dunce:
I know of pentographs being used at 132 and 400kv but don't know of any made for 34.5kv. Unless you are thinking of something else.
Julius Right
I am sorry. At first I didn’t know the voltage. Second neither even for above 132 kV indoor distribution like this I did not see for a long time. Now GIS it is more convenient. By the way, the line of circuit breakers are the ancient “Bulk Oil Circuit Breakers", indeed? I saw one like this for the last time 50 years ago.
For up to 36 kV I don’t know open installation else but Switchgear –metal clad-only.
mbrooke
Batteries Included
United States
Technician
This is an outdoor substation.
Vacuum breaker:
http://www.abb.com/product/db0003db004279/c12573990063647085256aea006dbae3.aspx
http://inv.bassmachinery.com/q/nlist/=,000920,20275734
Although they do look like bulk oil breakers lol. FWIW the final design might have SF6 instead.
Its ok, it varies. :)
