We have (2) 6000A switchgears, an A side and B side, fed from different sources. They are designed to have a bus duct that connects them, via a tie breaker located on the A side switchgear. This will provide redundancy in the event of a power loss - one switchgear can supply the other. With this design intent, the 6000A rating of each switchgear represents the combined calculated load of both gears. The EOR has sized the bus duct connection between the gears at 6000A as well, which seems unnecessary. By design, the bus would only ever see the load of either one gear, or the other. There is no scenario where the bus would ever take on the full load of both gears. Therefore, the bus should only need to be rated according to whichever gear has the highest calculated load. Correct?
Appreciate the input everyone.
