Re: Bus Protection
Sorry, Charlie, but I have to disagree on this one.
I would say "no" in any event. Your calculation is your calculation. If it shows more than 42 KAIC, then you have to have equipment rated for more than 42 KAIC. You have to protect the equipment against any fault that you believe is possible. You don't get the option of saying the calculation is conservative and the the result is "close enough."
That said, you do have an option of re-thinking your calculation. If you can justify a revision to the assumptions, and can obtain thereby a defensible result of 42 KAIC or under, then you can use that revised calculation as a basis for selecting the 42 KAIC bus.
