Brandon Loyd
Can anyone tell me if either one of these installations are illegal?
1st. The gutter is fed by a 400 amp breaker some 30'+ away with 400 amp wire. Then, using a multi-tap polaris fitting, they branch out with #12 wire to feed the 4 fusible disconnects directly attached to the gutter, which have 15 amp fuses installed, each having their own set of wires. I have seen this many times and never questioned it as the #12 wire, to me, is protected by the 15 amp fuses. Am I right or wrong?
2nd. These two fusible disconnects are fed via a bus tap from the bottom of this panel. They are within 10'. This installation appears to be code legal to me as well. Am I right or wrong?
