Bussbar ampacities
steveve1
Tucson, AZ
Seems to me there is a ampacity rating of 1/4 cu bussing based on sq. inches or the like. Can you shed a little light on this subject? Thanks always.
Re: Bussbar ampacities
I used to design transformers and we used either 750 or 1000 amperes per square inch for loading a bus bar. The last time I worked in that area was 1969 so the details are really fuzzy. It seems like we used 750 for Al. and 1000 for Cu. A ?" X 4" bus would be 1 square inch.
Keep in mind that I am going from memory and I was working for a manufacturer. I can't find where the Code addresses this issue. :D
A word of warning, do not try to compare bus sizing in a Listed product with any "standard" for current density. Manufacturers apply bussing based on actual temperature rise which includes factors like air flow and configuration.
The only place in the code book that I know of, that address buss sizing..
NEC'05, 366.23(A) Auxiliary Gutters
NEC'02, 366.7(B)
By the way, bus is spelled bus. However Bussmann people really like it when you use their spelling of buss. :D
