Buzzing Dimmer "whys it humming ,because it doesnt know the words"
Jerseydaze
Ok I have 6 5" Haol icat cans one one dimmer and 4 on another 75 watt par 30 Halogen used lutron diva 600 watt sp dimmers and dimmers buzz any sudgestions I am thinking about trying a 1000 watt dimmer
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
As Bob said I would try a different brand of bulb. I will almost guarantee you that is the problem.
Mr.Sparkle
Jersey Shore
It is perfectly normal for Lutron Diva 600w dimmers to buzz when dimmed, as long as you are under the wattage rating I would not worry.
I speak from having the experience of switching them out before to see if it was a problem with the dimmer, all 3 buzzed. I vote that is why they are $7.50 at the supply house.
Dennis Alwon
Chapel Hill, NC
The lamps/bulbs/silly technicality are GE I thought that was at least one of the top brands anyone make a suggestion on a better brand.
I have not had problems with philips or westinghouse brands. I not sure but I always use 130v bulbs because the filament is a bit stronger. I believe it is the filament that is vibrating.
Mr.Sparkle
Jersey Shore
I believe the OP is referring to buzzing coming from the dimmer itself due to the fact that I have had almost the exact same scenario with the same model dimmer.
Dennis Alwon
Chapel Hill, NC
Well I have installed hundreds of Diva dimmers and never had a dimmer buzz-- I guess it is possible I just have not experienced it.
Mr.Sparkle
Jersey Shore
I only ran into the problem once on multiple dimmers in the same house & I was wondering what could be causing it. I wonder if "dirty" electricity could cause such a thing, not that I know what I am talking about as far as using the term "dirty" but I mean interference of some form or another in the lines themselves?
RHJohnson
"bulb vs lamp" I hate to think gardners are more professional (or intelligent)than us. I have never heard a gardner call a bulb a lamp. Maybe the next time I need to change a fluorescent bulb I'll call a gardner...
cowboyjwc
Simi Valley, CA
Come on guys, you're picking the fly poop out of the pepper. Most of you say fixture, which is what plumbers install, you install luminaires.
