Buzzing Lights
I have just finished my basement and I have 10 can lights each with a 65W bulb on a 3-way dimmer switch that is rated for 1000W. When I turn the lights on at full capacity they are fine but when I start to dim the lights I get a buzzing sound coming from the lights which gets worse the more I dim. This is the second dimmer switch I have tried, the first dimmer was only rated for 600W with the same result.
Try high quality halogen lamps.
