BX/AC in Subpanel
noreply
New User
NYC
Handyman
The house I’m working on is over 100 years old. The main and sub are all BX/AC cable. I ran 2 dedicated lines with AC cable. Everything is testing proper ground. The one thing I noticed and am not sure is in violation is there is an aluminum bond jumper from neutral to panel back in the sub panel. I know ground and neutral should not be bonded after main disconnect. But since there are no ground wires or ground bus is that okay?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
