Is it "code" to use the metal sheathing on bx, mc or ac type cables as the only means of equipment grounding?
Let me explain. Older homes around here typically use bx style cable between the receptacles with no grounding conductor. Electricians use the metal sheathing on the cable as an equipment ground wire and simply attach a wire from the ground screw on the receptacle to a green ground screw on the back of the metal receptacle box.
Does this comply with the code requirements for equipment grounding? Is this method an acceptable method for equipment grounding when no ground wire exists?
I did a search on the forum without much luck. I believe I remember Mike Holt stating on several occasions this was not an acceptable or code accetptable method for equipment grounding!
Thanks in advance!
Joe Myers
Thanks in advance!
Joe Myers
