Hi, I do not speak English, I'm using a google translator.
I'm doing a paper on photovoltaics and I need some help with the translation "Diode by pass". This is what translated google translator .... could you correct the grammar?
There would be pictures, so it says in the following illustration.
1. In the normal operating conditions of a cell, schematized in the following illustration, the current generated by the cells is absorbed by the load (resistance R).
2. Photovoltaic module connected to a load (image)
3. Otherwise, in the following figure, it is reported that, following the fall of a leaf, one of the cells is shaded.
4. Shaded photovoltaic module without di-pass diode (image)
5. This cell stops generating current and in turn becomes a load by reversing its polarity and absorbing the electrical energy produced by the other cells with the effect of heating. In these cases, the reverse current passage can be hindered through the shaded cell (hot spot) by a bypass pass diode connected to the cell itself, as shown in the following illustration.
6. Shaded photovoltaic module with by-pass diode (image)
7. Theoretically, to provide the best system efficiency, a diode for each cell would be expected, but to simplify the production process and to reduce the cost of the modules, the manufacturing industries are usually used one every 18 or 20 cells. If a module is lying in the vicinity of shady objects (eg fireplaces, antennas, cables, etc.) its volumetric characteristic is improved by the by-pass diode. Without this, the whole current of the module would be determined by that of the shaded string. The following figure shows a 36-cell module with two diodes, which ensure that the maximum current flows through at least the unshaded eight cells.
8. Shading a cell of a standard 36-cell module with two by-pass diodes (image)
