Anyone know of a transfer switch that can have one power source and two loads connected, so you can switch the power supply from one load to another? So basically a manual bypass switch (DPDT), but instead of two power sources (grid & generator) wire it up backwards with one power source connected to the "load" terminals and two loads each connected to one of the "line" terminals?
I'm assuming I can't actually use a manual bypass switch for this application since it probably isn't UL listed or designed for that application. For example the load terminal probably don't have insulating covers that would safely allow one to connect a source at that connection point.
If anyone knows of a product that could accomplish this I'd appreciate it! Looking for something rated 200 A.
