Al Pike
- Honesdale, Pa
I will be wiring 1 signal wire(spec. stp#16)for a transducer in a wet well, 5 Intrinsically safe level floats(spec.3/c#14)wire,4#1THWN pump feeds w2 4/c#14 sensor wires from a control panel on a outside rack to a nema 4x jb on top of the wet well.The spec's.call for meltric switch rated plugs on the bottom of the jb supplied by the vendor. Q,Help with the correct wire/cable types,and what class would the CP outside on the rack be(50' away from the wet well),and can the sensor wires be installed in the same conduit as the pumps? Need help new to this type of work. Thanks so much.
