Based on 501.15 (B)2 when a conduit leaves a classified  area into a unclassified area there shall be no fitting used between the seal and where the conduit leaves the classifed area. My question is i need to pennetrate a 3/16" steel plate wall to enter into a unclassifed area where the control panel is housed. what are my options for properly passing through the wall it seems everything would be a code violation
1. welded coulping it the wall
2. classifed bulk head fiiting
3. weld a ridgid nipple into the wall
does welding void the UL rating on the fitting, there has to be something that will work, i need advice Thanks,
