msshel0
- Evansville, IN, USA
I am retrofitting and existing system with controls upgrade. The application is that I am purging & pressurizing (type Z) a panel that will have connectors on it.
I have a connector that only has IS circuits in it. Since I'm using IS barriers, I should be able to use normal wiring methods. However after a brief search, I see that Harting sells an Intrinsically safe connector, but I can't really see much difference between it and a regular connector. Do I have to have a special connector for an intrinsically safe circuit, or can I use a regular connector?
I also have motors that will be fed from this panel. Even though the panel is purged, I still have to use a C1D2 Plug or better because the Purge and pressure are on the inside of the panel and the connector is on the outside, correct? The purge and pressure will not cover a plug connected to the panel.
