rdkazmier
- United States
- Controls Engineer
Hello - I have an C1D2 application that will be using a NEMA 4X enclosure with a type "Z" purge/pressurization system. This is going to be for a pump skid and house VFD's, their associated circuit protection, and some control circuitry. We are being asked to provide the following external devices on the enclosure: Start/Stop Push button, Pilot Lt indicating ON condition, Speed Potentiometer, Panel Meter displaying motor speed , and Disconnect. I can understand the Start/Stop pushbuttons and Pilot Lt as I can find C1D2 rated operators. The thing that has me concerned is the disconnect (I am assuming that they want a thru-door style) and potentiometer requests.
Being that this will be a purged/pressurized enclosure, does that impact the rating of the devices that are allowed? I can I use a thru-door disconnect that is NEMA 4X (or for that matter a speed potentiometer that is NEMA 4X). What is considered "internal" to the enclosure? Is any part of a device that is mounted through the enclosure considered "external" and need to be rated C1D2? My gut tells everything external should be C1D2 but I am looking for any direction on where to look standard wise to verify what is needed/required
I have already e-mailed the manufacturer of the panel meter's to verify whether their units are suitable for a pressurized enclosure or if they need to be contained within the enclosure behind a window etc. They state that they are "suitable" for C1D2 applications but I would rather be safe than sorry.
Any help/guidance would be greatly appreciated!
