vinod
- Saudi Arabia
I have a C400, cable-mounted CT that cannot be installed because the CT's inner diameter is too small for the cable.
As a solution, I am planning to install a spare class TPS CT that can fit the cable.
I think that there should be no problem with replacing the C400 CT with the class TPS CT because the class TPS CT has a higher breakdown voltage. According to the manufacturer's curves, the C400 CT breaks down at around 900V, whereas the class TPS CT breaks down at around 1,600V. The two CTs have the same ratio.
What other factors do I need to consider if I want to justify replacing the C400 with the class TPS CT?
Thanks
Thanks
