Hello everyone,
my name is Oliver. I'm an electrical engineer from Germany. My company ist starting to build machines for the USA and now I have to design the first control panel. It's quite a challenge because there are many differences between northern american and european regulations. I studied UL 508A and NFPA but I'm still not sure about a particular problem.
Our machines shall be designed for ambient temperatures of -40 to +40 °C (-40 to 104 °F). The main switch is interlocked with a thermostat because there are devices which are only suitable for temperatures greater than 0 °C (32 °F). In case of a longer blackout the cabinet has to heat up before main switch can be turned on. Therefore the heater circuit has to be derived before main switch. According NFPA this would be an excepted circuit. So I need a disconnecting means, isolating transformer, and overcurrent protection. Right?
The cabinet is supplied by WYE 208/120 V. Technically i would't need a transformer because I already have 120 V for the heaters. If I need a transformer nevertheless I would use a 208/120 V isolating transformer. Is this excepted circuit also a control circuit and therefore limited to 15 A? In this case i would need a second transformer because one doesn't have enough power. Besides the heaters there are other devices which have to be derived before main switch, e. g. lighting, receptacle, air conditioning unit. Two transformers would be pretty "unpleasant". I appreciate any advice.
