When installing multi-conductor [MC] type cable in tray using the higher ampacities based on proper cable spacing etc. How is it affected when you transition to conduit for a short run? I thought it was based on a percentage basis [for example if it is less than 10% of the overall run] then you can continue to use the free-air higher ampacity rating but cannot locate this reference in the code and hoping someone could point me in the right direction…Thanks
