Sierrasparky
- USA
- Electrician ,contractor
How do you size these cable grips. They will be used on #2 triplex and on #4 triplex.
Also where can you get them online?
I will use a wedge clamp on triplex. Almost a foolproof install and low cost.
https://www.homedepot.com/p/Halex-4-1-0-Service-Entrance-SE-Wedge-Clamp-Connector-51062/100171929
Wedge clamps you claim are not suitable have a range of sizes they work on. #2 and #4 typically are both within range of some common wedge clamps out there.How do you size these cable grips. They will be used on #2 triplex and on #4 triplex.
Items like you pictured generally are designed for one size cable only and you must use a different catalog number for #2 then you would use for #4.
Add: I think they often will have a color stripe on them that is a quick way of identifying size - probably same color scheme as connection devices often use - blue is 6 AWG, orange is 4 AWG, red is 2 AWG, yellow is 1/0.
