Cable Lashing/Bracing for various fault currents
I am trying to find out if there is a standrard lasshing/bracing methodology for cables in gear for bracing purposes. Siemens has some reccommendations but does not cite any testing agency data as the basis for its reccommendations. The issue arises from a lashing requirement that is contained in a set of engineering specs for a fed project (it does not cite a standard either). The gear we are using is not Siemens so it would be problematic to use their reccommendation docs as a submittal for another manufacturer's equipment. (you know, most engineers I know want everthing to match up).
Does anyone have any links or guidance? The gear that we are using is Square D. but the info does not have to be Square D specific if it is a standard/manufacturer agenecy/organization document.
