Cable Lighting
Having a hard time finding anything in the code book concerning #10 insulated Kevlar core suspended cable lighting wire. The manufacture specification cut-sheets say that it is sufficient for lenghts up to 30' and rated for 300 watts. No voltage or temp rating in the specs.
Isn't there something in the code that refers to this Kevlar cable?
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I suspect this is part of a manufactured fixture system. Kevlar is not mentioned in the nec but doesn't need to be if used as listed.
Very much appreciate your "Jonny on the spot" response to my question.
Thank you
