kendrichchan
cable limiters are short circuit devices that can isolate a fault cable.
a cable limiter is a short circuit device only?
So, it's basically a single element fuse housing only the short circuit interruption portion of dual element fuse?
all the limiters I've seen where constructed with several (many) elements rather than one single link. As I understand this design feature reduces the possibility of a sustained arc. (provides several points of burn off).
Cable limiters are not really used to protect the cables. The are normally used at both ends of cables that are connected in parallel. This lets the cable limiter clear the faulted cable and keep the other conductors of the parallel circuit in service. Other applications are for multiple loads fed off a single source. Here again they are intended to clear the faulted cable and keep the other loads in service.It should be noted that cable limiters seem to be a USA idea, they are virtually unknown here in the UK.
Most UK or European electricians or engineers would not know of them. ...
In institutional, commercial, and industrial systems, cable limiters are used at both ends of each cable on three or more cables per phase applications between the transformer and switchboard, as illustrated in the diagram and photographs. In residential systems, the cable limiters are normally installed on a single cable per phase basis at the source end of the lateral feeder to each residence.
