bphgravity
- Florida
We have alot of open lanai (porches) closed in and made into what they call a "Florida Room". Many of these are a foam and aluminum panel construction. Along the bottom is a channel for the installation of cables for power and lighting. Per 820.133(A)(1)(2), would coaxial cable be permitted to be installed in these channels along with the NM cable? The section uses the term "conductors" and not "cables". Does that make a difference?
Also, the Exception #1 to 800.133(A)(2) and 820.133(A)(2) read exacxtly the same except for a little comma betwen "nonmetallic-sheathed" and "Type AC". Which one is it suppose to be?
The way the 820 section reads, it appears to be one cable - a nonmetallic sheathed AC cable. The way the 800 section reads, it appears to be two separate cables. NM and AC.
The handbook is no help.
