To pick a nit, the shield is not always a signal path in coaxial cable. For unbalanced connections is is but for balanced connections it isn't.Only one end connected if it's only a used as shield, both ends have to be connected when it's also a conductor (e.g. coax cable).
It would be possible to build that device- not that difficult actually, but if the shield is a conductor you have to account for how the signals will behave across the switching element; if nothing else, there will be a blip in the impedance.
Saw the Video. Q: is there any automatic way ( device ) or method to prevent or isolate or interrupt etc. the increased voltage/amperage from frying the shield of the cable etc. and preventing a fire, when you lose the neutral ? or is this impossible to do ?
Accepted, OTOH how much coax is used as balanced? (Is even possible? I expect you can with triax but I've never thought about it.)To pick a nit, the shield is not always a signal path in coaxial cable. For unbalanced connections is is but for balanced connections it isn't.
Balanced microphone cables are coaxial with two inner conductors. Maybe that's what you mean by "triaxial" but I have never heard them called that.Accepted, OTOH how much coax is used as balanced? (Is even possible? I expect you can with triax but I've never thought about it.)
Irrespective of what you call them, for unbalanced connections through shielded cable with a single inner conductor the shield is part of the signal path and must be connected at both ends, while for balanced connections through shielded cable with two inner conductors, it isn't and should only be connected at one end if the devices at both ends are connected to AC power through a three prong plug. This is true for audio, anyway.Balanced mic cables wouldn't be coax(ial) at all since the conductors don't share a common axis. I suppose you could refer to low-frequency shielded twisted pair (e.g. mic cable) as "twinaxial" but I can't think of anyone who does.
IME "twinax" refers to a balanced twisted pair enclosed in a shield and designed for >1MHz signals; an early example is the cabling for IBM 5250-type terminals and IBM mid-range systems (System/3, /34, /36, etc). IIRC it's also used in 10G ethernet DAC cables and other fancy stuff.
That's pretty much what I said.Irrespective of what you call them,[...]
About the best use for the stuff, even when new. (I installed a non-trivial amount of twisted-pair with baluns in place of twinax, wouldn't touch the actual twinax.)when the IBM stuff went away, I converted a lot of twinax into pull rope for CAT5 cable.
While some experts feel that in some situations, a XLR balanced interconnect cable may have the shield connected at the send end only.while for balanced connections through shielded cable with two inner conductors, it isn't and should only be connected at one end if the devices at both ends are connected to AC power through a three prong plug. This is true for audio, anyway.
Let's keep the difference between installed cable, where it's easy and practical to connect only one end, and portable cable, where you need both ends connected so it's contiguous through multiple cables.a XLR balanced interconnect cable may have the shield connected at the send end only.
As to the OP's question, the instructions for the Jensen CATV isolator show the incoming drop connected to a ground block first, then the isolator goes between the ground block and the customer's equipment. So, foreign neutral current could still flow through the drop and the customer's ground system (and N/G bond) in a code-compliant install even with the isolator.
But microphones are not connected to AC power, so yes the shield can be connected at both ends and usually is. It has to be for phantom power to work, but even with dynamic mics there is no reason for it not to be.While some experts feel that in some situations, a XLR balanced interconnect cable may have the shield connected at the send end only.
While other experts feel that the shield should be connected at both ends.
Microphone cables often require the shield connected at both ends for phantom power.
If the shield is connected only at the send end, then the receive end often has a hybrid shield connection of a radio frequency capacitor.
While this may be true in a large multi-buiilding studio (but experts have different views on this). Correctly wired components shouldn't have 'ground loop' problems with it. The 1995 'Pin 1 Problem' papers covered correct design.If the devices at both ends are connected to AC power with grounding the shield should only be connected at one end because if they are connected at both ends it likely will result in a ground loop with current flowing in the shield.
