SparkyMc Sparkface
New member
- Loudoun Co Virginia
Hello all. Long time lurker, first time posting a question...
I am constructing a three-car, 1,650 sq/ft detached garage for residential/ private use in Northern Virginia. There is a split 400 amp service located 375 feet away in an existing outbuilding. The split service serves 200 amps at the outbuilding, and the remaining 200 amp service is for feeding the new detached garage. Therefore, we will have a 200 amp sub-panel located in the new detached garage with main disconnect located in the outbuilding.
The main service disconnect is 375 feet away. The detached garage will have a car-lift, commercial wood shop equipment, lots of lighting, and a mini-split heating/cooling system. We have estimated approximately 80 amps continuous load.
Our main concern is voltage drop over such a long distance. I have complete confidence in my electrician, however feel an obligation to my customer to verify correct load vs. voltage drop calculations.
Here is my question: What size feeder cables should we use to feed a 200 amp sub-panel 375 feet away with min. 80 amp continuous load?
Thank you in advance for your time.
Matt
Matt
