Hassan Asran
- Jeddah
Hey,
we facing a problem in one of our project that needs your advice, the problem is that the low voltage 380V/220V switchgears from EATON being ordered to our project are coming Circuit breakers with terminal Mechanical lugs size 750KCMIL from Ilsco part # D3591 and Compression lugs size 750KCMIL from HEX part # HSBL-750L2 while the size of the cable we shall terminate to it is 768KCMIL, Please advice is it correct or not to use this lugs ? and we thought to use cable reducers but i couldnot find a reducer from 768KCMIL to 750KCMIL as it is very small difference, can any body can support me with a code or a response which i can use to convince my client that this lugs are still correct to terminate this cable to it and no need to change it to bigger size .... please advice.
thank you.
thank you.
