A/A Fuel GTX
- WI & AZ
- Electrician
Is it necessary to cap off unused ports on a cable splitter?
You also need to keep in mind, CATV is an RF product. So by using cheap "Walmart" cable or improper terminations you can cause signal degragation, bleed over and allow outside RF signals into the system.
This is how CB and HAM radio interfere with CATV quality.
Yeah, but it's the responsibility of the CATV accept all interference.
It is also the responsibility of the CATV device in question NOT to interfere with amateur radio. I know, I have worked with our cable company to locate the source of RFI coming from a cheap amp someone installed in their home. The FCC will fine people for not making the required corrections if they are interfering with radio communications. They even fine power companies for having arcing insulators that interfere with amateur radio communications.
