Cable Strippers
Jim1959
Longmont, CO
What have you found to be most effective for stripping large copper conductors? I just ordered a couple of Greenlee G2090 strippers, but they don't seem to have great reviews.
I used to use a klein banana blade style folding knife and a sharping stone to keep the edge for decades,they were reliable.
Once I misplaced it now I just use the razor knife it works great as well.
Unfortunately our safety department won't even allow the use of retractable razor knifes to strip wire.
Have they found a solution? I love people who pronounce how not to do stuff without knowing how to do it another way.:rant:
Not saying a razor knife is safe, far from it......
I too like the Klein "linoleum" knife, but usually use the razor knife.
Maybe get the safety folks to buy chain-mail gloves when a razor knife is needed. ;)
https://www.amazon.com/Stainless-Steel-Mesh-Hand-Glove/dp/B000NNT2GW
Does not matter. Insulation thickness is not consistent enough and many cables are extruded in a way where thickness varies. There is no better device. However cut resistant level 3 gloves prevent cuts. If you try to use one of the supposed strippers and you nick the conductors then the installation fails.
This is where you are a qualified worker, a professional. So you refuse to do work that violates state law. Call state department of labor. Either the plant stays down until safety manager comes up with a way it can be done safely to Code (state law) or the plant stays down. If you are fired you will be paid back pay and state goes after company:
As a contractor we’ve seen this before. We cancel the job.
I used to have a whole drawer of knife alternatives. Ripley Tools makes a lot. Really hard insulation like URD works but not the common ones.
I was going to suggest those gloves.
They use them in meat packing houses.
