Patrick Gorrell
New member
- Lakeland Fl
Does higher temp rated cable have slightly more copper? If no, then how does higher temp rated insulation reduce teh temp rise at a CB connection limited to 40C? Higher rated insulation intuitively resists deterioration at higher heat levels but is it a fuction of heat dissapation along the cable length lowering connection heat?
If yes, there's more slightly more copper in a 75C vs 60C, it makes sense a higher temp cable with more copper/same ampacity generates less heat.
