resistance
- WA
Do you see a problem with this install. It?s a four conductor cable going directly to an LB that?s installed outdoors. Once the cable enters the interior of the PVC LB, the sheathing is removed, but the conductors continue (without splice) into an outdoor nema 3r panel. The cable is secured within 8 inches of the PVC conduit body (LB). My thoughts: Code complaint?as the cable is secured, and is not susceptible to damage. Your thoughts?
