PSU Electrical
- Bethlehem/Scranton
Have a project we are designing that we have decided to go with Cable Tray for. Project is very process oriented with a lot of control cables and small motors/pumps on VFD's. Our controls/automation group has chosen two different types of Belden cable to use which is tray rated - Belden 29512 and Belden 1055A. The 1055A control cable is 600V rated and the 29512 is 1000V shielded VFD cable; the automation guys like it because it has a signal pair included they they take to the aux contact at the motor disconnect. Per NEC 392.20 (B), since the cable is not MC cable, do I need to have the barrier to separate the cables because they have different insulation ratings? If I do have the separation barrier in the tray, what happens when you come to an intersection and power and control is going in various directions and you have overlap of the cables?
