Cable tray can be connected to the grid anywhere but is not required to be connected to the grid anywhere.
General facts, but code references may be dated...Make sure the cable tray has an adequate bond jumper between each section. One grounding point to the grid would then be enough.
In a industrial plant application, does the ground conductor on a cable tray have to be grounded to the grid at multiple points or can it just be at one location, such as the electrical building?
