tompoff43
- Cincinnati
- Electrical designer
Can you stack exterior cable (ladder) tray? FYI, it will contain multi conductor cables (power and low voltage) and yes it will have a divider.
How will you access the bottom tray to pull cable or will they be a gap?Can you stack exterior cable (ladder) tray? FYI, it will contain multi conductor cables (power and low voltage) and yes it will have a divider.
While I’m not sure of any obvious violations I would say that whoever is going to be pulling wire might cuss.Will keep minimum distance from top to bottom of upper tray. 2-3” or so.
