Hi everyone
I'm working on a machine which has this long tray route. This machine is like a 25x10x10 metres dimensions and tray is serving every equipment around it and on top of it. I'll have 3 ground bars on 3 different locations all of them will be connected to a grounding pad on further side of the building.
My questions are:
1- Can i have multiple ground connections on this single tray, for example can i ground the tray on location 1 then can i ground the tray on location 2 and 3 again ? Is this going to cause any problems. Or do i have to ground this tray on location 1 and then i can't ground it again ?
2- I have many equipments being served from this tray. So if i ground equipment 1 on the closest location 1, can i ground my equipment 2 on location 2 ?
3- If i have a motor to ground which has a different tray for 3 phase power transmission. Let's call it tray 1 for power and tray 2 for low voltage signals. Can i ground my motor chassis on tray 2 on location 2 and ground the tray 1 on on location 1 ? I hope that's not too confusing.
Please note these are ground bars and main grounding pad is in a different place connecting all bars together.
Thanks for your answers in advance.
My questions are:
