- Bremerton, Washington
- Master Electrician
A question came up from a contractor on cable tray.
Cable tray is a support system and can be used with any wiring method.
The confusion is on installing Tray Cable. If for example, a 12-2 w/ground 600V jacketed tray cable jacketed cable, is a divider needed from limited energy cables, such as coax or class 2 ethernet?
I understand the divider is needed from single conductor tray cable, such as 1/0.
