New EE
- California
Is it permissible to run 16 awg 600 volt insulated cabling (being used for a 16 vac transformer) in the same conduit where there is 18/2 unshielded, 18/6 shielded, and CAT5e cabling in the conduit?
I wanted to provide only one conduit to go from a door that has a card reader and directory entry phone (that needs a 16 vac transformer to power it) and run all the wiring in the same conduit
from the door to the comm room that is located on another floor but wasn't sure if I can run the 16 awg 600 volt insulated cabling in the same conduit with the other cabling per code. Thanks.
